Reply to topic  [ 8 posts ]
 heater box ? rattle
Post heater box ? rattle
This yutz of a Yank needs a little sage advice. I've yet to figure out how to post pics but working on it.
I'm beyond the run in period on my rebuilt 602 and now that I can rev a bit more aggressively I have found a tin sounding rattle. Much like a heat shield rattle on newer cars. I suspect the heater boxes . If I grab each box and shake they both move a bit on the exhaust. One more than the other.
As this is the only 2cv near by (that I know of in lower Michigan) any suggestion as to approach would be helpful and most welcomed.
Should there be a clamp on the box as the exhaust enters the box or might there be another fitting needed. Gasket? This is the only running one I've ever seen. So I'm a real green horn in my 1970 Bamboo want-a-be :)
September 17th, 2022, 3:07 pm
Post Re: heater box ? rattle
Hi, the heater boxes are spot welded to the tubes. So you can try to weld them, i hammered the flanges over on one of my car and put a heavy duty jubilee clip on it. Bit of copper grease on the screw.
September 17th, 2022, 10:48 pm
Thanks for the info. Not only do they slide back and forward but the twist a little. Thise spots welds must have let go.
So happy to be on the forum :D
September 18th, 2022, 1:57 am
Yes they rust loose in time. Very thin tin... ;-)
September 18th, 2022, 2:14 pm
Welcome to the forum :D .... how did you sneak in! :lol:
Ideally, you would have the cases welded to the pipe (though I have also used a jubilee clip ;) ).
Before welding, it's a good idea to check the pipe is installed at the correct angle, as if it's not, and you need to remove it, it can be a bugger to re install.
Don't ask me how I know :D
September 18th, 2022, 7:27 pm
Roger V wrote:
... Before welding, it's a good idea to check the pipe is installed at the correct angle ....
There's a Dutch company that could do with heeding your advice Roger. ;)
September 19th, 2022, 12:13 am
+1 on the welcome!
I've never known these parts not to be rattley and loose. Thought it was normal.
Regarding pictures, I found you have the shrink them quite a bit before the system will accept them. Works better for me on my laptop than my phone.
September 19th, 2022, 7:13 pm
Yes, as Ian says, check the files sizes. I find cropping an image can reduce the size substantionally. Though, could be, you have not been a member long enough, or, not posted enough posts.
September 19th, 2022, 9:52 pm
