Page 1 of 1
[ 4 posts ] |
Dennis
Joined: March 24th, 2009, 9:18 pm Posts: 248 Location: 15340 Mourjou France
 Headlight adjustment
The knob under the dashboard will adjust the headlights on my Red Special, but at present it offers the option of a range between "dipped quite a lot" and "quite dipped".
Apart from bending the brackets the headlight shells sit on (or more likely bending the shells), is there some further scope for adjustment?
The threaded adjustment mechanism on the light bar at the end of the long rod from the dashboard looks a bit battered, and I am loath to try bending that in case I snap it off.
On my 1964 H-Van, which uses what are said to be 2CV headlights, the metal headlight shell sits on a thick cup-shaped washer. If you loosen the 19mm nut underneath, you can re-position the headlights quite a lot: the hole in the mounting bracket is oversized. Of course the H-Van doesn't have any other way of adjusting the headlights: the mounting brackets are welded to the panels on either side of the radiator.
And I wonder whether the older 2CVs used a similar cup-shaped washer?
_________________ Dennis usually in the Cantal
1964 HY 72 (Type H, campervan) - LHD 1969 AZU 250 (formerly French Post Office van) - LHD 1982 Red Special - RHD 1983 Burgundy/Black Charleston - RHD 2017 Skoda Octavia Estate 1.4 DSG - LHD
| August 22nd, 2021, 1:51 pm |
rob massey55
Joined: December 21st, 2014, 7:33 pm Posts: 900 Location: Rhayader Mid Wales
 Re: Headlight adjustment
P1000993 by Robndaisy, on Flickr The set up on the AZU. P1010185 by Robndaisy, on Flickr The set up on the Charleston. P1010187 by Robndaisy, on Flickr Once slackened, plenty of adjustment  .
| August 22nd, 2021, 5:25 pm |
Dennis
Thanks Rob. I'll start squirting in the penetrating oil.
| August 22nd, 2021, 6:37 pm |
chevrons2
Joined: April 9th, 2010, 12:21 am Posts: 464 Location: West Sussex
If both beams are at the same level and the headlamp mounting/adjustment nuts are seized, you can raise the range of the internal adjuster mechanism by adding another washer under the split-pin (or R-clip). This will swivel the headlamp bar to a slightly higher angle, raising both beams.
| August 23rd, 2021, 1:34 am |
Page 1 of 1
[ 4 posts ] |
Users browsing this forum: No registered users and 91 guests |
