View unanswered posts | View active topics It is currently June 19th, 2026, 2:02 am
Reply to topic  [ 8 posts ]
 suspension
Post suspension
Hi all,
Just a small point: just been underneath to try to grease the knife-edge, (not sure of the best way to achieve that), when I noticed that the front wheel suspension units are fitted so that the cowling edge is facing forward.
Is this the right way, becasue surely the road dirt etc is likely to get sploshed inside the cowling.
I'm not worried, just wondering.
Car's an '82 Charleston.
Thanks all.
May 16th, 2021, 1:49 pm
Post Re: suspension
In the citroen maintanace book they to put grease on with a brush. Suspension units have rubber hamonica covers on normally.
May 16th, 2021, 6:34 pm
Post Re: suspension
Old cars like 2CV are notorius for rust traps due to negligent design.
Looks like they had lost all hope on fighting the tin worm.
Could you please post a pic of it?
I've Been Wrong Before.
May 16th, 2021, 9:18 pm
Post Re: suspension
Thanks for that.
I think I've just had a Doh! moment: re the units facing the wrong way. If I simply refit them the other way round that will solve the situation. Is it that simply?
I assume the eye holes on the dampers on each end are the same diameter.
May 17th, 2021, 5:24 pm
Post Re: suspension
http://www.international2cvfriends.com/forum/viewtopic.php?f=7&t=1924
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
May 17th, 2021, 6:23 pm
Post Re: suspension
Don't just refit them the other way round, as specific shocks demand specific orientation. Depends on the brand as you may see on the suggested topic.
May 18th, 2021, 9:44 am
Post Re: suspension
Here's a pix of the front damper unit, the car front is to the left in the pix.
I can't see any makers mark so don't know if they are fitted the correct way round.
All I say is that during the six years I've had this car I've never been aware of 'handling' problems, maybe understeer when pushed hard, but I suspect that's just a characteristic of the 2cv.
May 24th, 2021, 4:23 pm
Post Re: suspension
I'm sure Ken posted on here about correct fitting. Or somewhere anyway. :)
May 24th, 2021, 5:55 pm
