View unanswered posts | View active topics It is currently April 28th, 2026, 12:00 pm
 Carb Heat Insulation Block
Post Carb Heat Insulation Block
Hi :)
Can someone possible tell me the dimensions of the carb insulation block please. :)
I'm having a play with a throttle body. :D
January 26th, 2021, 12:09 am
Post Re: Carb Heat Insulation Block
@Roger : there are two sizes, 11 mm and 6,7 mm thickness.
January 26th, 2021, 8:43 pm
Thanks Edce
As you mentioned differing sizes, I looked on Ecas site, and they mention 9.5mm !!!
No big deal, as I'm just playing with the idea at the moment. :D
January 26th, 2021, 10:18 pm
This Carb Heat Insulation Block, is outlawed in 2Cv racing if used in excess of height, because it increases the engines torque. (According to John Nash book) :geek:
I've Been Wrong Before.
January 29th, 2021, 11:28 pm
@taskos
That's interesting .... Did he say why it increased torque?
January 30th, 2021, 12:46 am
Not really.
The only prevision is said to have enough room under the bonnet.
January 30th, 2021, 5:36 pm
FYI
Carb extension
https://youtu.be/_XbFiTBBTpw
January 30th, 2021, 6:24 pm
Interesting!
Could be as much about getting air out of the engine compartment as anything.
A velocity stack is another thought, But I was under the impression that was more to help idle than top end torque.
Another, another thought ..... Is turning the individual horizontal airflow pulses into a single vertical flow.
Not something that helps the average car though :)
January 30th, 2021, 6:44 pm
https://youtu.be/FGgiCoJ_9xg
January 30th, 2021, 9:31 pm
Stick your neck out and take as much as mossible dense air !!! Keep it cool :lol: :lol:
January 31st, 2021, 11:00 am
