| Fuel pipe size http://international2cvfriends.com/forum/viewtopic.php?f=7&t=6338 |
Page 1 of 2 |
| Author: | Roger V [ October 23rd, 2020, 2:08 pm ] |
| Post subject: | Fuel pipe size |
1978 602 Can anyone with easy access, please measure (unless you know) the metal fuel outlet from the tank. I think its sucking air there somewhere, and its a bit of a patchwork. Thanks |
| Author: | Edce [ October 23rd, 2020, 3:26 pm ] |
| Post subject: | Re: Fuel pipe size |
Hi Roger, I measured it to be 6 mm outer diameter. |
| Author: | Roger V [ October 23rd, 2020, 4:08 pm ] |
Thanks buddy, guessed it was about that. |
| Author: | Roger V [ October 23rd, 2020, 6:05 pm ] |
Ive ordered hose and clips. So anyone got any tips as to the easiest way to change the rubber hose? Does the tank have to drop all the way out? |
| Author: | Edce [ October 24th, 2020, 9:13 am ] |
Dropping the tank is the most "sure" method of replacing the fuel line. Due to the lack of space it is too risky of squeezing the line. |
| Author: | Richardw [ October 24th, 2020, 5:51 pm ] |
Definitely easiest with the tank dropped all the way, curse those rear seatbelt fittings that did away with the access hatch! |
| Author: | Roger V [ October 24th, 2020, 6:29 pm ] |
Richard I'm fortunate to have a Bedouin with wooden floor and access hatch, but still can't see under the cross member! Still, not a bad idea to take it out completly, as i have a submersible fuel pump that i would like to see if it can be fitted. |
| Author: | Edce [ October 25th, 2020, 9:17 am ] |
I too have a submersible fuel pump stiil to install Roger. So keep us posted on how you will install it ! Thnks |
| Author: | AZL57 [ October 27th, 2020, 7:30 pm ] |
Take the tank of when it's nearly empty. My brother once found out when a full tank he was unbolting hit him in the face... |
| Author: | Roger V [ October 27th, 2020, 10:35 pm ] |
I did a simular thing with my old 2cv. A full tank is suprisingly heavy when your stuggling under the car. |
