View unanswered posts | View active topics It is currently June 19th, 2026, 2:03 am
 Fuel pipe size
Post Fuel pipe size
1978 602
Can anyone with easy access, please measure (unless you know) the metal fuel outlet from the tank.
I think its sucking air there somewhere, and its a bit of a patchwork. :)
Thanks
October 23rd, 2020, 2:08 pm
Post Re: Fuel pipe size
Hi Roger, I measured it to be 6 mm outer diameter.
October 23rd, 2020, 3:26 pm
Thanks buddy, guessed it was about that.
October 23rd, 2020, 4:08 pm
Ive ordered hose and clips.
So anyone got any tips as to the easiest way to change the rubber hose? Does the tank have to drop all the way out?
October 23rd, 2020, 6:05 pm
Dropping the tank is the most "sure" method of replacing the fuel line. Due to the lack of space it is too risky of squeezing the line.
October 24th, 2020, 9:13 am
Definitely easiest with the tank dropped all the way, curse those rear seatbelt fittings that did away with the access hatch!
1978 2cv6 Vert Bamboo
October 24th, 2020, 5:51 pm
Richard
I'm fortunate to have a Bedouin with wooden floor and access hatch, but still can't see under the cross member!
Still, not a bad idea to take it out completly, as i have a submersible fuel pump that i would like to see if it can be fitted. :)
October 24th, 2020, 6:29 pm
I too have a submersible fuel pump stiil to install Roger. So keep us posted on how you will install it ! Thnks
October 25th, 2020, 9:17 am
Take the tank of when it's nearly empty. My brother once found out when a full tank he was unbolting hit him in the face... ;-)
October 27th, 2020, 7:30 pm
I did a simular thing with my old 2cv. A full tank is suprisingly heavy when your stuggling under the car. :)
October 27th, 2020, 10:35 pm
Users browsing this forum: No registered users and 223 guests
