Page 1 of 1
[ 5 posts ] |
paulkell
 Steering Wheel Swap
Is it a simple swap from 2 spoke steering wheel (D*lly) to a single spoke (Charleston) type? Someone told me the column needs rotating by 90 degrees to correctly position the single spoke - is this correct? If so, straight forward? ta
| September 21st, 2020, 5:24 pm |
48pop
Joined: May 23rd, 2011, 7:14 pm Posts: 309 Location: ecosse
 Re: Steering Wheel Swap
As I recall, it does need to be rotated......You need to take out the bolt at the base of the column, (in the engine bay) Pull the column up and rotate.....Getting it all pointing in the straight ahead direction can be a challenge ....I had a couple of goes at it !
| September 21st, 2020, 6:05 pm |
chevrons2
Joined: April 9th, 2010, 12:21 am Posts: 464 Location: West Sussex
If you've still got the steering lock ring fitted, you'll need to remove that first in order to pull the column up high enough to clear the pinion.
| September 22nd, 2020, 1:01 am |
48pop
chevrons2 wrote: If you've still got the steering lock ring fitted, you'll need to remove that first in order to pull the column up high enough to clear the pinion. Ahhh, My steering lock was removed, (after it locked up unexpectedly  )
| September 22nd, 2020, 9:30 am |
Terry
Joined: November 4th, 2009, 4:00 pm Posts: 526 Location: Confederate state of South Yorkshire
I swapped my two spoked "standard" 2CV {Special} steering wheel for a single spoke {Charleston/Club/Dyane?} wheel ....the spoke now resides at somewhere around the 10or11 o-clock position ....which to be perfectly honest, is no problem at all IMHO. BTW ....just a thought, but I was under the {prob'ly mistaken} impression that the idea of a single spoke was so that the steering wheel "collapses" easier in the event of a collision ...therefor it would seem rather silly {IMO} to position the spoke at anything like 5 to 7 o-clock. T.
_________________ Remember .....the drive is the reason,the destination is just the excuse. 2CV6 Special [Red] C4 VTR+ Coupe [Black] C1 UrbanRide[Blue & Orange] {Ltd Ed}
| September 24th, 2020, 2:47 am |
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 219 guests |
