| Gear Change Rod Buzzing http://international2cvfriends.com/forum/viewtopic.php?f=7&t=6332 |
Page 1 of 1 |
| Author: | Roger V [ August 29th, 2020, 10:41 am ] |
| Post subject: | Gear Change Rod Buzzing |
Hi Anyone have a method of adjusting the gear stick to stop the gear rod buzzing in forth gear please? |
| Author: | subarupete [ August 29th, 2020, 3:07 pm ] |
| Post subject: | Re: Gear Change Rod Buzzing |
New rubber |
| Author: | AZL57 [ August 29th, 2020, 5:07 pm ] |
Or an extra washer between clip and rubber. Do you have the spring washer under it. |
| Author: | Roger V [ August 30th, 2020, 9:26 pm ] |
Ah! I should probably havecsaid, ive had the gear stick out ... |
| Author: | Geert [ August 31st, 2020, 7:11 am ] |
Roger V wrote: Ah! I should probably havecsaid, ive had the gear stick out ... If it is still buzzing when it is out, you should consult a wizard. Catweazle for instance |
| Author: | Roger V [ August 31st, 2020, 7:23 pm ] |
I've tried to be a bit scientific about it and adust it a little at a time. I think it was under tension when in gear, and a lot of vibration was being transmitted through it. It's a little better. Perhaps when i get it right, i make some alighnment marks on it. |
| Author: | EirikJ [ August 31st, 2020, 10:04 pm ] |
Just hang something heavy on it. Like a good Bluetooth speaker if you got no car stereo, or a bag of beers. F*** these old cars. They are ATTENTION WHORES. |
| Author: | Geert [ September 1st, 2020, 8:58 am ] |
Roger V wrote: :lol: I've tried to be a bit scientific about it and adust it a little at a time. I think it was under tension when in gear, and a lot of vibration was being transmitted through it. It's a little better. Perhaps when i get it right, i make some alighnment marks on it. I like catweazle better. My brother had the same problem with his 2CV special. It is years ago, so I remembered as you mentioned the tension just now. It takes a little fiddling to have it right, but it is a good idea to make some marks if it is correctly fitted. |
