Roger V
 Gear Change Rod Buzzing
Hi  Anyone have a method of adjusting the gear stick to stop the gear rod buzzing in forth gear please?
| August 29th, 2020, 10:41 am |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2257 Location: Near Monmouth
 Re: Gear Change Rod Buzzing
New rubber  on the top of the gear box lever ?
| August 29th, 2020, 3:07 pm |
AZL57
Or an extra washer between clip and rubber. Do you have the spring washer under it.
| August 29th, 2020, 5:07 pm |
Roger V
Ah! I should probably havecsaid, ive had the gear stick out ...
| August 30th, 2020, 9:26 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1205 Location: Magyarország
Roger V wrote: Ah! I should probably havecsaid, ive had the gear stick out ... If it is still buzzing when it is out, you should consult a wizard. Catweazle for instance
| August 31st, 2020, 7:11 am |
Roger V
| August 31st, 2020, 7:23 pm |
EirikJ
Just hang something heavy on it. Like a good Bluetooth speaker if you got no car stereo, or a bag of beers. F*** these old cars. They are ATTENTION WHORES.
| August 31st, 2020, 10:04 pm |
Geert
Roger V wrote: :lol:  Harry Potter, eat your heart out.  I've tried to be a bit scientific about it and adust it a little at a time. I think it was under tension when in gear, and a lot of vibration was being transmitted through it. It's a little better. Perhaps when i get it right, i make some alighnment marks on it.  I like catweazle better. My brother had the same problem with his 2CV special. It is years ago, so I remembered as you mentioned the tension just now. It takes a little fiddling to have it right, but it is a good idea to make some marks if it is correctly fitted.
| September 1st, 2020, 8:58 am |
