View unanswered posts | View active topics It is currently April 28th, 2026, 12:01 pm
Reply to topic  [ 2 posts ]
 valve seal
Post valve seal
Hi all,
Messing around with an old engine today, looking at the valves etc.
I notice that new valve seals available seem to have a rubber seal lip.
On the one I have I cannot see any rubber but it is a tight fit on the valve stem. Should there be a small seal inside the item in the pix.
I suspect that newer seals are cheaper to produce than the originals.
Thanks.
August 5th, 2020, 11:22 am
Post Re: valve seal
The valves on the pics are complete, but very tired, no extra rubber necessary. I guess you will change them in any case.
August 5th, 2020, 3:16 pm
Users browsing this forum: No registered users and 78 guests
