View unanswered posts | View active topics It is currently April 28th, 2026, 12:00 pm
Reply to topic  [ 6 posts ]
 Brake pipe seals....assembly question
Post Brake pipe seals....assembly question
Rookie order of assembly question......
1. Does the seal go on to the pipe first then insert into wheel cylinder
or
2. Stick the seal into the cylinder, then push in the pipe????
June 15th, 2020, 1:09 pm
Post Re: Brake pipe seals....assembly question
I do it as mentioned in 2.
But my brother does it as in 1.
June 15th, 2020, 4:54 pm
1
June 15th, 2020, 6:31 pm
1
I've Been Wrong Before.
June 16th, 2020, 10:14 pm
New seal then 2.
Used seal which is already in the hole then also 2.
With 1 the seal can go wrong into the hole.
June 17th, 2020, 5:00 pm
not if you give the seal enough fish :D
June 17th, 2020, 5:20 pm
Users browsing this forum: No registered users and 78 guests
