View unanswered posts | View active topics It is currently April 29th, 2026, 8:07 pm
 Cylinder head temperature
Post Cylinder head temperature
Anyone know what the ideal temperature is for the 2cv engine (late 602) to run at?
The Bedouin has an area under the grill that is allowing a large volume of air to over cool in winter. I need to block some off.
I can purchase a cylinder head temperature (cht) sensor, but it won't mean a lot unless I have some idea of what it should be.
January 28th, 2020, 12:51 pm
Post Re: Cylinder head temperature
Sensor under the plug approx 200 deg C, from memory???
In manifold see pics
ps
With the thermocouple under the plug are very fiddly to fit.
January 28th, 2020, 2:35 pm
Thanks Pete
I've ordered one (under plug), let's see what I get. :)
How did you calibrate?
January 28th, 2020, 8:07 pm
What did you buy?
January 28th, 2020, 8:45 pm
Thought I would try one of these
https://www.ebay.co.uk/itm/Universal-Cy ... 2171263927
January 28th, 2020, 8:59 pm
Ungrounded needed you can then power the set up from the car supply.
Start with this battery display
https://www.ebay.co.uk/itm/TM-902C-K-Ty ... SwKeNd0geP
Peter
January 28th, 2020, 9:21 pm
It will take few days to arrive. However, I may have ordered the wrong type. :roll:
We will see. What I think I require is a resistive type. The same as a water temperature sender would be.
I'm after connecting it into my Speeduino for when I'm running on petrol.
I have this whizzy Android app to monitor it when running on Speeduino..
January 28th, 2020, 10:46 pm
@What I think I require is a resistive type.
That will be a "Thermistor" used for Oil and Water temp (max temp approx 130 deg C.)
"TC's" (Thermcouple) signal gives Mille volts but can measure very high temps eg exhaust.
January 29th, 2020, 10:24 am
Thanks Pete
I did a little more research last night, and it needs an amplifier. :roll:
Its ordered :) it will be interesting connecting it all up. :D
January 29th, 2020, 12:14 pm
Did a quick search for EGT on Speedunio but didn’t find much, what did you find re amplifier with Speeduino ?
January 29th, 2020, 2:04 pm
