Page 1 of 1
[ 4 posts ] |
Edce
Joined: October 12th, 2019, 6:40 pm Posts: 164 Location: Limburg Belgium
 Oil pressure
I am curious about the level of oil pressure we can expect in the 2cv engines (602 and 652 cc). I have installed an oil pressure reading gauge. At idle I measure 20 psi (1,2 bar) and at around 4000 rpm, it is 60 psi (4,4 bar). Anybody has same experience ?
| June 12th, 2020, 6:10 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2254 Location: Near Monmouth
 Re: Oil pressure
From https://www.citroenspecialsclub.org/pub ... /page1.phpAfter starting the car and left to warm up to a steady idle the readings were 115 psi at 6000 rpm 90 psi at 3000 and 50 psi at 1000 I then went on a blast for 1/2 hour reaching 60ish mph. After this the readings were 90 psi at 6000 rpm 60 psi at 3000 rpm, at idle the reading was 20 psi dropping to 15 psi after a couple of minutes.
| June 12th, 2020, 7:26 pm |
Taskos
Joined: February 22nd, 2012, 10:34 am Posts: 422 Location: Greece
 Re: Oil pressure
According to Haynes manual:
A79/0 and M4 35.5 to 44 lbf/in2 @4000rpm A79/1 57 to 71 lbf/in2 @6000rpm M28 and m28/1 78 to 92 lbf/in2 @6000rpm
| June 16th, 2020, 10:02 pm |
Edce
 Re: Oil pressure
Thnks Taskos, I have a Visa engine but the values seem to be similar.
| June 17th, 2020, 8:50 am |
Page 1 of 1
[ 4 posts ] |
Users browsing this forum: No registered users and 94 guests |
