View unanswered posts | View active topics It is currently April 29th, 2026, 2:37 am
Reply to topic  [ 4 posts ]
 Citro??n Gearboxes (OK, includes H-Van)
Post Citroën Gearboxes (OK, includes H-Van)
I recently splashed out nearly €23 on Citroen's special tool 1677-T, used for the set-screw heads that I think only Citroën ever used:
In my case it was so I could undo the gearbox from the engine of a 1960s HY-78, but you'll see from Der Franzose's catalogue that they were also apparently used on DSs and 2CVs - presumably the older models.
The picture also shows an actual bolt and socket.
I am curious to know what advantage this shape of head actually has? It obviously didn't catch on widely.
My other question, though, is about a tag I found rivetted to the top of the H-van gearbox:
There's nothing similar on my own H-van gearbox, and I wonder if perhaps it was put there when the gearbox was rebuilt. If so (or even if not!), could anyone suggest what the numbers might mean?
My own guess was that the number on the right might have been the odometer reading when the gearbox was installed (as this was 80000 or so when the van was eventually taken out of circulation). But the other one - 103?
Dennis usually in the Cantal
1982 Red Special - RHD
August 20th, 2019, 6:50 pm
Post Re: Citroën Gearboxes (OK, includes H-Van)
I have seen this type of plates on several 2cv boxes too. The older ones mostly. I think they are serialnumbers from production.
September 4th, 2019, 8:22 am
Should anyone still be interested in this, I have now got that gearbox fitted to my h-van and it evidently WAS a rebuilt box. I bought it with the complete front end of an h-van. The rear end had been cut off.....
The gearbox is noticeably quieter, it doesn't leak, and it even has nice clean synchromesh on 2nd and 3rd gears - previously I was double-declutching. It was the box from an HY78, so it has slightly longer ratios - I get an extra 5kph in top gear, meaning in practice an impressive 85kph cruising speed.
But whether that extra tag with the numbers had something to do with the rebuild I still can't say.
November 3rd, 2019, 11:56 am
Tag has nothing to do with the rebuild. It's factory rivited. Ps, the tool is also used on some gas cilinders for welding.
November 3rd, 2019, 4:26 pm
Users browsing this forum: No registered users and 104 guests
