48pop
Joined: May 23rd, 2011, 7:14 pm Posts: 309 Location: ecosse
 435 to 602
Hi Folks,
Is there a definitive, step by step guide for this swap??
I've read the cats-citroen.com website but still have some confusion....
I have a '74 AZU250, with 435cc/drums and on an original chassis. My first 500mile drive home was not a pleasant experience.....pretty scary on any kind of incline...
I can get an M28 with box and discs, I assume I would need new rear cylinders/master Cly, fluid flush ...anything else needed??? Any handbrake issues
Should I get the M28 and look for a 602 drummer gearbox?
Does anyone have a 602 drummer box in their shed?? Cheers Gerry
| July 14th, 2019, 1:25 am |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2289 Location: South-Limburg
 Re: 435 to 602
If your brakes are ok they will work just as well.
| July 14th, 2019, 10:05 pm |
Derek
 Re: 435 to 602
The original drum brakes were very good. Every bit as good as discs, and the handbrake was far superior. Maintenance was more difficult though. It sounds like yours need overhauling - you may find a leaky slave cylinder spoiling the plot.
| July 15th, 2019, 9:03 am |
Roger V
 Re: 435 to 602
Can't say I'm knowledgeable in this area.
But a bit confused as to the issue!
What was the issue coming back. Lack of power on incline, or lack of brakes on decline.
Guys, will an M28 fit on the 435 gearbox?
| July 15th, 2019, 9:32 am |
jasu
Joined: August 8th, 2012, 11:00 am Posts: 508 Location: Korpilahti, Finland
 Re: 435 to 602
Roger V wrote: Guys, will an M28 fit on the 435 gearbox? Yes. And drum brakes from that gearbox is direct fit to either gearbox...
| July 15th, 2019, 9:51 am |
bobh
 Re: 435 to 602
I did a similar swap and used a later drum brake box. I never liked the small engine with the centrifugal clutch. The drum brakes are good. Good enough to snap the UV joint on one occasion. The only "problem" I had was that the chassis engine mounting holes are not wide enough for the 602, and I had to drill another hole in the chassis. My engine uses one original hole and one offset hole, so the engine is out of alignment a little bit - but no major problem in the last 20,000 km. - Oh and you need a new clutch and brake pedal assembly. Mail me if you want my notes on a 425 to 602 conversion. BobH
| July 16th, 2019, 9:05 am |
48pop
 Re: 435 to 602
Hi BobH,
Sent you a PM...
CHeers Gerry
| July 18th, 2019, 7:09 pm |
48pop
 Re: 435 to 602
Roger V wrote: Can't say I'm knowledgeable in this area.
Guys, will an M28 fit on the 435 gearbox? It was the power on the incline.....no issues with the brakes !
| July 18th, 2019, 7:10 pm |
Roger V
 Re: 435 to 602
So, it would appear you can chuck a 602 on it as is (some work required for mount alignment). Personally, I would do that and worry about the gearbox later, if its working ok.  From what I understand, the vans are a bit like trying to push a brick through the air, so a lower ration can be preferred. Try it  )
| July 19th, 2019, 10:49 pm |
samfieldhouse
 Re: 435 to 602
You can chuck an M28 on a 435 box... but you will hear it SCREEEEEEEM
| August 6th, 2019, 10:12 pm |
Users browsing this forum: No registered users and 66 guests |
