View unanswered posts | View active topics It is currently June 19th, 2026, 2:03 am
Reply to topic  [ 4 posts ]
 Exhaust Gas Temperature
Post Exhaust Gas Temperature
For those who love gauges..
EGT on the cheap.
LED Display needs 12volts and earth (< £4 delivered)
(Temperature shown (Deg C) with sensor resting on the exhaust)
EGT Sensor (Ungrounded K Type) (< £7 delivered)
Could be mounted with the probe in the Exhaust manifold with BSP Thread.
Banggood - Example of Display (Discard thermocouple supplied as the "+" is connected to the shield)
Banggood - Example of EGT sensor (ungrounded)
June 19th, 2019, 1:26 pm
Post Re: Exhaust Gas Temperature
Want want want.. For my Beamer. Great find...
June 20th, 2019, 12:04 am
Manifold with plug fitted and drilled.
Drilled 8mm then tapped 1/8" x 28TPI BSP (British Standard Pipe)
Yet to be welded in place.
June 20th, 2019, 2:35 pm
Fitted and Working.
August 7th, 2019, 4:28 pm
Users browsing this forum: No registered users and 224 guests
