View unanswered posts | View active topics It is currently June 19th, 2026, 4:47 am
Reply to topic  [ 25 posts ]  Go to page 1, 2, 3  Next
 Brake Fluid Leak
Post Brake Fluid Leak
I have a small but significant leak of LHM from the Red Spécial, and I am fairly sure that where it is going is between the plastic reservoir and the cast metal master cylinder.
The reservoir can be wobbled slightly on top of the cylinder, and when I do that there appears to be a very small bubble or two of LHM between the plastic and the metal. There's evidence of leakage on the body and the RH steering arm further down.
The wheel cylinders and disk mechanisms all look nice and dry.
Is there some kind of replaceable washer underneath the reservoir? Or something to tighten up?
I'm always a little nervous of attacking the braking system, but this definitely needs attention.
I'd really appreciate advice.
Dennis usually in the Cantal
1982 Red Special - RHD
March 12th, 2019, 2:32 pm
Post Re: Brake Fluid Leak
It could be, the reservoir is just not seated probably. My experience is they can be difficult.
Should you need seals, you can get them here. You require lhm seals for lhm. ;)
https://www.ecas2cvparts.co.uk/-c-38_46 ... 044b482f11
March 12th, 2019, 2:44 pm
Some advice here:
http://www.2cvgb.co.uk/forum/showthread ... post211585
March 12th, 2019, 4:34 pm
Derek :)
You have to be able to log in to see it. ;)
March 12th, 2019, 6:23 pm
This is advice given to me by Ken Hanna when I had to replace the reservoir seals.
'standing on the offside of the car, take hold of the reservoir and push/twist it inwards, so 'clockwise' when viewed from the front.
That 'rolls' the bayonet fittings on its base out of their seals.
When refitting, smudge LHM over the seals and the prongs on the underside of the reservoir and push it straight down.'
Good luck and check to see that the Reservoir has no cracks, mine did!
March 12th, 2019, 8:35 pm
Thanks Roger - I was forgetting that!!
March 12th, 2019, 10:35 pm
Would that be these two little things?
https://www.ecas2cvparts.co.uk/seal-under-reservoir-master-cylinder-57129-pair-notes-p-1233.html?WSid=fef1904c77a94d043dc683044b482f11
Does the master cylinder just push down onto them? I am not sure that there is really a bayonet fitting.
March 12th, 2019, 10:37 pm
It are those seals. The reservoir can be taken of the master cylinder by pushing it away sideways. Do it slowly and if it is still full hold some vessel under it. Normally it will pop out of the seals. Good luck.
March 12th, 2019, 11:16 pm
Take a look at the reservoir also shown on the link I included and you can see the shape. Its not attached other than inserting it. It can require a robust approach to insert or remove. I would check it is seated properly in the first place. :)
March 12th, 2019, 11:29 pm
Also worth checking that the seals are correctly seated into the master cylinder before inserting the reservoir's (non-quick disconnect) bayonet prongs.
Once again, lubrication with LHM will help to ensure a leakproof fit...
March 13th, 2019, 1:54 am
Users browsing this forum: No registered users and 226 guests
