View unanswered posts | View active topics It is currently June 19th, 2026, 3:55 am
Reply to topic  [ 3 posts ]
 Lighting Problem
Post Lighting Problem
Hi all, interesting problem with the headlamps has developed!
When full beam is on & the engine is reved past tick over, the alternator is charging off the scale on my dash mounted voltmeter at 16+ volts. :shock:
Have tried another new voltage regulator, but no different. Cleaned &, replaced where needed, all lighting connectors.
any ideas :idea: Only have this charging fault when full beam is on.
September 4th, 2018, 4:20 pm
Post Re: Lighting Problem
Disconnect the regulator and connect it directly to the alternator exciter, and positive and negative terminals on the battery and see what happens.
September 4th, 2018, 6:11 pm
Many thanks, but problem solved. :lol:
The earth by the top of the drivers side (RHD) heater tube was loose! Had the car in bits a while ago, must have forgot to tighten it back up.
A lot to be said for having a dash mounted accessory voltmeter, if I did not have one fitted I would have had no idea, it may well have ended in disaster.
September 4th, 2018, 9:01 pm
Users browsing this forum: No registered users and 214 guests
