View unanswered posts | View active topics It is currently June 19th, 2026, 4:46 am
 Heater tubes and vent pipes
Post Heater tubes and vent pipes
Advice needed regarding vent pipes to windscreen and heater tubes. In 25 years of 2CV ownership I have never had a 2CV with no vent pipes fitted. I have now acquired such a vehicle where the vent pipes are just left loose in the car.
There is no means of attaching both pipes to the bulkhead and it would appear the connectors are missing. I have no idea what the connectors look like and also would anyone have a pair I could buy or alternatively who would stock them.
The heater tubes, also not fitted - there are two short rubber sleeves or connectors on the bulkhead, which I have never seen before on a 2CV. I assume heater tubes are forced into these sleeves?
2CV is a 1990 Special.
August 17th, 2018, 11:29 am
Post Re: Heater tubes and vent pipes
Hi :D
An image may help identify the setup and way forward.
August 17th, 2018, 11:52 am
Hi Roger, have taken several photos but won't be uploaded as too big apparently. I have no idea how to reduce them in size.....!
August 17th, 2018, 4:02 pm
Hope this photo helps showing the two rubber sleeves on bulkhead of engine bay. Cabin bulkhead just shows two holes where connectors for vent demisters should be .......
August 17th, 2018, 4:30 pm
easy way to show photos is via a hosting site I use. https://imgbb.com/login
Instagram @mobylette
August 17th, 2018, 9:16 pm
Never seen a double version?
August 17th, 2018, 9:53 pm
Someone has thought the demisting qualities needed improving!
The right hand (as seen from the driving position) cylinder usually vents to the under parcel shelf vent, and the left hand to the junction with screen/floor selector flap (lhd cars). The connections are cardboard tubes.
Yours has two junction boxes. Not a bad idea.
A 1967 car (lhd)
August 18th, 2018, 9:29 am
The demisters are stuck in from the inside and than screwed to the bar under the windscreen with 2 parkers.
August 18th, 2018, 12:17 pm
If you crop an image, that will most likely reduce the size of the file and enable you to post on site.
I think you have the standard setup for late 2CVs.
Pipes from heat exchangers go to the lower middle bit. Pipes then go from there to the demisters.
There is a push-pull knob under the dash to direct heat to screen or footwell.
Heater tubes are available from ECAS. They are foam lined and considerable reduce engine noise entering the car.
August 18th, 2018, 12:55 pm
Standard on right hand drive cars from about 1980 onwards.
August 19th, 2018, 10:19 am
