View unanswered posts | View active topics It is currently June 19th, 2026, 6:19 am
 Fitting a Dash Cam with Rearview Cam.
Post Fitting a Dash Cam with Rearview Cam.
I've been thinking about fitting a dash cam for quite a while now and I've just been looking on Amazon and found one that is integrated with a rear view mirror that attaches over the original mirror and is held in place by rubber straps. The kit comes with a rearview camera that can also be connected to a reversing light so it activates when reverse gear is engaged to allow you to see the view behind you via the screen display, so I'm thinking that would be a useful bit of tech if a 2CV actually had reversing lights, which clearly it doesn't. So my query is this... Is there a 2CV parts supplier that does a kit which operates a switch at the gearbox to power a reversing light? I might as well get the full use of the dash cam kit if I can.
July 31st, 2018, 12:16 am
Post Re: Fitting a Dash Cam with Rearview Cam.
Your late 2cv will probably have a fitment at the rear of the gearbox to take a reversing switch. The older cars didn't have this, at least, that is what I have read elsewhere. I rigged up a rear brake switch from a motorcycle fitted to the 'Y' section, and attached to the gear lever from the gearbox by galvy wire, cable tie, and bit of old inner tube placed in such a position that the switch was only activated in the reverse position. Worked well as an alternative.
ImageReverse sw 001 (Medium) by D Reynolds, on Flickr
July 31st, 2018, 7:59 am
As Derek says, it's dependant on the rear plate of the gearbox.
If I remember correctly, there is a ring that needs drilling and tapping. The switch then screws in and the switch is operated by the reverse gear rail.
https://www.ecas2cvparts.co.uk/reversin ... -1938.html
Edit
Just realised that ECAS explains this much better than me :lol:
July 31st, 2018, 11:37 pm
In the 60s and 70s they had a kind of bridge like plate bolted on the gearbox lid and there was a brake switch on it that was operated by the gear-stick.
August 1st, 2018, 5:08 pm
Thanks for the replies chaps. Can't believe I missed the switch on the ECAS website. I did take some time to look before I posted the thread. I'm a little apprehensive about drilling through the body of the gearbox as I don't fancy risking any shards of metal dropping inside the 'box and getting thrown around by the oil. I'd rather look at fitting a switch externally if possible, so something like the other two posts.
August 1st, 2018, 7:21 pm
The back plate would have to be removed to drill and tap. ;)
I like the idea of of using the gear stick (on the box) as a reference though. :)
August 1st, 2018, 7:47 pm
:oops: Ahhh! Right, I'll be asking my mechanic mate about doing that then. Thanks Roger.
August 1st, 2018, 9:23 pm
If you tilt the engine/gearbox forward some 45 degrees you don't even have to take the oil out of the gearbox to remove the back plate.
August 2nd, 2018, 7:29 am
VGS in Belgium sells a kit which places a switch so that it will be operated by the gear lever.
January 20th, 2019, 6:10 pm
Post Re: �Fitting a Dash Cam with Rearview Cam.
Hi all! Going to attempt this operation to mount a switch in my gearbox. Is there anything I need to be aware of when taking off and mounting the back cover? Like springs that will come flying or bearings that need to be kept in a particular position?
April 8th, 2023, 8:17 pm
