Page 1 of 1
[ 7 posts ] |
Steering pulling to the side
EirikJ
When driving on flat road, the steering pulls a little to the right. If the road leans to one side the steering pulls to that side, but this is normal? The toe in/out is correct, I believe. Adjusted it, measuring with a home made contraption Did no difference. I'm thinking it may be one of the front arms that are bent slightly so camber is wrong. Any idea what usually causes a 2CV to pull to one side? I guess I can easily check the camber angels compared to each other with just a string over the tyre by the rim?
| July 8th, 2018, 6:43 pm |
Roger V
 Re: Steering pulling to the side
How are your tire pressures and conditions?
| July 8th, 2018, 8:03 pm |
EirikJ
New Michelins with the same pressure in each.
| July 8th, 2018, 9:28 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1205 Location: Magyarország
I would check the camber the way you describe it. Maybe you got in a ditch somewere in the verge of the road.
| July 9th, 2018, 7:47 am |
AZL57
Or a brake blocking a bit on one side?
| July 9th, 2018, 8:03 am |
EirikJ
Brakes are perfect. I think I will start by figuring out a way to check the camber. It's quite expensive in the workshop
| July 9th, 2018, 11:42 pm |
Roger V
How are your kingpins?
| July 10th, 2018, 1:01 am |
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 223 guests |
