Two Chevrons
Joined: August 17th, 2010, 11:47 pm Posts: 194 Location: Chichester West Sussex
 Alternator id please
_________________ 1972 dyane4 435cc
| June 24th, 2018, 6:01 pm |
Two Chevrons
 Re: Alternator id please
Sorry for the repeated pics
| June 24th, 2018, 6:02 pm |
Two Chevrons
 This is my new acadiane does anyone recognise it
| June 24th, 2018, 6:31 pm |
Two Chevrons
Thanks in advance
| June 24th, 2018, 6:32 pm |
Roger V
Someone had a similar problem not to long ago. If I recall it was cured with new brushes. Heat expansion was breaking a contact.
| June 24th, 2018, 7:27 pm |
Two Chevrons
Thanks Roger worth a try, just need to source some now, we think she's a visa alternator
| June 24th, 2018, 8:07 pm |
Roger V
Take them out and take a look.
| June 24th, 2018, 8:54 pm |
Two Chevrons
I did that they look ok one is shorter than the other I did a resistance test on them when cold and was fine from the contact on the ring to the connector end
| June 24th, 2018, 11:36 pm |
bobh
The exciter wire looks like it has a nasty kink in it a couple of inches from the alternator. Is the wire good ?
| June 25th, 2018, 7:46 am |
Two Chevrons
bobh wrote: The exciter wire looks like it has a nasty kink in it a couple of inches from the alternator. Is the wire good ? I'll check the resistance with a wiggle good spot!
| June 25th, 2018, 8:46 am |
Users browsing this forum: No registered users and 233 guests |
