View unanswered posts | View active topics It is currently April 28th, 2026, 7:59 pm
Reply to topic  [ 5 posts ]
 wheel bearing seal query
Post wheel bearing seal query
Hi, getting a bit confused with the sequence of seals to bearing on front wheel of a 1986 2cv saloon.
I bought a new bearing, for a previous 2cv along with the two seals a while ago.Ii have dismantled the hub, (great fun!) and found the two seals I removed are smaller than the new ones. As the pix shows, the smaller seal fits in the outside of the hub carrier(?) while the new larger seem to be a loose fit inside.
Does the bearing have seals each end inside the hub?
The new seals are from Ecas so I suspect it's me being a plonker!
I've read the Haynes manual and it seems vague.
Thanks for any help.
Chris
June 8th, 2018, 5:33 pm
Post Re: wheel bearing seal query
From ECAS site.
Wheel bearing seal, front bearing requires 2, rear bearing requires 1, size 45x62x8.
June 8th, 2018, 8:56 pm
Thanks Ken for your quick reply. It's amazing how a cup of tea and a sit down can clear the brain!
Of course, (I now realize) seals can't go inside the housing considering the lock nut requires a tight fit and any seal would crush. Also why did I have two rear seals: I forgot I usually buy two of such items in case I damage the first.
I had to cut off the locking nut with a dremmel and slightly damaged the hub thread, I now have to try to persuade the new nut to catch the thread.
Any problem and I shall stop for a a cup of tea!
Chris
June 9th, 2018, 7:04 am
Try something like this :)
https://m.ebay.co.uk/itm/Metric-thread- ... SwbF1aGeZc
June 9th, 2018, 7:41 am
Thanks for the link Roger.
Just finished the re-assembly of the hub.
I managed to 'cut' a new thread by using a breaker bar to turn the lock nut, a very long, slow and hard process. A touch of grinding paste, then WD40 then thin oil. There was very little swarf and both threads still have nice contours so I reckon it's fine. Not very professional but it worked!
Looking forward to my next bodge!
June 9th, 2018, 1:53 pm
