View unanswered posts | View active topics It is currently June 19th, 2026, 6:56 am
Reply to topic  [ 8 posts ]
 Coil heat
Post Coil heat
having had starting problems when hot, I've fitted a new coil. Starts great, hot or cold, but I opened the bonnet after a long run and the coil was very hot. Is this normal?
November 4th, 2017, 5:01 pm
Post Re: Coil heat
They will get warm, but should not get hot.
If you have points ignition, it could be to much dwell.
November 4th, 2017, 5:44 pm
Post Re: Coil heat
By "Too much dwell" does this indicate that the cam which opens the points has lost its profile?
November 7th, 2017, 9:07 am
Post Re: Coil heat
Bobh, it's much more likely that the points gap is too small.
I use a dwell meter to adjust the gap with the engine running, rather than relying solely on a static setting with feeler gauges.
November 7th, 2017, 11:56 am
Post Re: Coil heat
So, what sort of dwell meter would you use on a 2cv as most meters are 4/6 or 8 cylinder. Can you use the 4 cylinder setting and divide by (er? 4). ?
Bob
November 7th, 2017, 8:02 pm
Post Re: Coil heat
Bob
Yes, use the 4-cyl setting but divide by two
November 7th, 2017, 9:33 pm
Post Re: Coil heat
Actually it's the same setting as for 4-cylinder,
due to the "waste spark" ignition system.
I've Been Wrong Before.
November 8th, 2017, 8:05 pm
Post Re: Coil heat
Not on either of my dwell meters!
November 8th, 2017, 9:47 pm
Users browsing this forum: No registered users and 207 guests
