View unanswered posts | View active topics It is currently June 19th, 2026, 10:31 am
Reply to topic  [ 6 posts ]
 Engine Running On
Post Engine Running On
After a run of about 10 miles or so, sometimes the engine will run- on after the ign is switched off. Is this an indication of poor ignition timing? When I replaced the condenser and points, I timed as per the book, using 6mm rod in the flywheel, putting a mark on the flywheel/crankcase etc.
October 26th, 2017, 2:21 pm
Post Re: Engine Running On
Hi Bob
First guess would be a hot spark plug. Look for deposits on the plugs. If they are suspect, there is usually a page in Haynes of the different issues with plugs.
Roger V
October 26th, 2017, 4:30 pm
Mine does sometimes, as above- check plugs. If I let it idle for ten seconds it doesn't happen.
October 27th, 2017, 9:59 pm
I cure this one by fitting the B7HS plugs.
I've Been Wrong Before.
October 28th, 2017, 8:48 pm
check the timing
October 29th, 2017, 8:04 am
Sounds like a job for today, Check timing with a strobe - the plugs are relatively new. Thanks for the advice guys.
BobH
October 29th, 2017, 8:33 am
Users browsing this forum: No registered users and 251 guests
