Recommendation for carb overhaul kit.
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=5992
Page 1 of 2
Author:  Devils Advocate [ May 4th, 2017, 7:37 pm ]
Post subject:  Recommendation for carb overhaul kit.
Hi all.
This is a very low mileage Solex 26/35, so no actual metal wear, so no jets etc required. But it is old so diaphragms etc. will likely be perished.
Where do folks go for a gasket/rubber-bits only kit?
Thanks.
Author:  Roger V [ May 4th, 2017, 8:00 pm ]
Post subject:  Re: Recommendation for carb overhaul kit.
I usually go to ecas for bits
http://www.ecas2cvparts.co.uk/-c-13.html
Don't be put off by the P&P looking a bit high as there is usually a refund a few days later.
This doesn't mean parts aren't available elsewhere. :)
Author:  Devils Advocate [ May 5th, 2017, 12:53 pm ]
Thanks Roger - I'll have a good look through.
Author:  Sean [ May 6th, 2017, 8:45 am ]
Devils Advocate wrote:
Hi all.
Thanks.
rubber bits?
theres an o ring on the acc jet and thats it
Author:  Derek [ May 6th, 2017, 9:31 am ]
Unless he means the accelerator pump diaphragm?
Author:  Roger V [ May 6th, 2017, 10:35 am ]
What's the acc jet :?:
Author:  Devils Advocate [ May 7th, 2017, 1:03 pm ]
Tee-hee!
Yes, I mean the accel diaphragm (and the choke pull-off one too?)
The carb is typically 2CV old, but less than 10k miles. So I'm assuming no actual wear but plenty perished bits...
Author:  Sean [ May 7th, 2017, 9:36 pm ]
accelerator jet
Diaphragms arent rubber
Author:  Devils Advocate [ May 15th, 2017, 12:17 am ]
Rubbery, then...
Author:  Derek [ May 15th, 2017, 1:36 pm ]
As has been mentioned:
http://www.ecas2cvparts.co.uk/-c-13_15. ... =1&sort=3a
A few rubbery bits in there.
I'm guessing you have what you need now?
