View unanswered posts | View active topics It is currently June 19th, 2026, 10:54 am
 Recommendation for carb overhaul kit.
Post Recommendation for carb overhaul kit.
Hi all.
This is a very low mileage Solex 26/35, so no actual metal wear, so no jets etc required. But it is old so diaphragms etc. will likely be perished.
Where do folks go for a gasket/rubber-bits only kit?
Thanks.
May 4th, 2017, 7:37 pm
Post Re: Recommendation for carb overhaul kit.
I usually go to ecas for bits
http://www.ecas2cvparts.co.uk/-c-13.html
Don't be put off by the P&P looking a bit high as there is usually a refund a few days later.
This doesn't mean parts aren't available elsewhere. :)
May 4th, 2017, 8:00 pm
Thanks Roger - I'll have a good look through.
May 5th, 2017, 12:53 pm
Devils Advocate wrote:
Hi all.
Thanks.
rubber bits?
theres an o ring on the acc jet and thats it
May 6th, 2017, 8:45 am
Unless he means the accelerator pump diaphragm?
May 6th, 2017, 9:31 am
What's the acc jet :?:
May 6th, 2017, 10:35 am
Tee-hee!
Yes, I mean the accel diaphragm (and the choke pull-off one too?)
The carb is typically 2CV old, but less than 10k miles. So I'm assuming no actual wear but plenty perished bits...
May 7th, 2017, 1:03 pm
accelerator jet
Diaphragms arent rubber
May 7th, 2017, 9:36 pm
Rubbery, then...
May 15th, 2017, 12:17 am
As has been mentioned:
http://www.ecas2cvparts.co.uk/-c-13_15. ... =1&sort=3a
A few rubbery bits in there.
I'm guessing you have what you need now?
May 15th, 2017, 1:36 pm
Users browsing this forum: No registered users and 218 guests
