turbofiat124
Joined: August 31st, 2016, 12:12 pm Posts: 322 Location: Hawkins County, TN. USA
 Warning lights
Why did Citroen mount the warning lights below the steering column? I think the ones in the 2CV are roughly 8mm. Like these: http://www.ebay.com/itm/262783020988 I noticed there was room for 2 more bulbs above the charging and brake fluid test lamp. I bought some of these indicators and plan on relocating the main beam, turn signal and emergency light to this location so I can actually see it without taking my eyes off the road. So they will be: Blue : Main beam Red: charging indicator Green: turn signal Orange: emergency flasher The brake fluid test light bulb stopped working for some reason so I'm not too concerned about. I got to wondering if the reason I can't remove the speedometer cover surround is I need to disconnect the speedometer cable from the gearbox first then the thing should slide right out. Hopefully.
_________________ http://s222.photobucket.com/user/turbof ... t=2&page=1
| March 31st, 2017, 1:14 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2254 Location: Near Monmouth
 Re: Warning lights
Those led lamps are reliable and are good in daylight, but at night you will get Retina damage
| March 31st, 2017, 1:27 pm |
Roger V
 Re: Warning lights
Consider leaving the main beam indicator where it is, as it will be an annoyance if it is to high up.
| March 31st, 2017, 2:06 pm |
 Re: Warning lights
Charging indicator? Isn't that the 'low oil pressure' warning light?
| March 31st, 2017, 7:40 pm |
richardmorris
Joined: July 9th, 2009, 10:27 am Posts: 493 Location: Bagshot Park
 Re: Warning lights
If there's a full set- blue main beam, green indicator, red hazards, red fog light, red brake fluid, red oil pressure - have I missed any?
| March 31st, 2017, 9:32 pm |
AZL57
 Re: Warning lights
Isn't fog light orange?
| April 1st, 2017, 8:53 am |
richardmorris
 Re: Warning lights
Just testing
| April 1st, 2017, 8:42 pm |
samfieldhouse
 Re: Warning lights
turbofiat124 wrote: The brake fluid test light bulb stopped working for some reason so I'm not too concerned about.
Is that not an MOT requirement? Quote: 2.11 Brakes These will be inspected to check:
their condition, including inappropriate repairs or modifications their operation and performance (the efficiency test) - the wheels and trims aren’t removed as part of the test the anti-lock braking system (ABS) and electronic stability control (ESC) (where fitted) The dashboard warning lights will also be checked for the ABS, ESC, electronic park brake and brake fluid warning lights.
| April 2nd, 2017, 8:44 pm |
richardmorris
 Re: Warning lights
He's in the USA, so rules may be different I suppose.
| April 2nd, 2017, 9:05 pm |
turbofiat124
 Re: Warning lights
On US spec cars anyway, as far as I can remember, the parking brake and low brake fluid switch share a single light "BRAKE" which lights up for a few seconds then goes off after you start the car.
The 2CV is the first car I've ever seen where there is a test button to see if the bulb is not burned out. Wouldn't it make more sense for the test light button to test all the warning lights, not just the low brake fluid light?
By the way, just because the bulb is good, doesn't mean the low level switch in the reservoir cap is working. So what's the point?
Mine stopped working for some reason. I swapped bulbs but it still doesn't light up. I don't know if it's the switch or what.
As far as the warning lights goes, I think I'm just going to relocate the original lights. Those super bright warning lights might get on my nerves after awhile.
| April 3rd, 2017, 1:10 am |
Users browsing this forum: No registered users and 108 guests |
