View unanswered posts | View active topics It is currently April 30th, 2026, 12:18 am
 Rubber gaiters
Post Rubber gaiters
Why is todays rubber rubbish? I bought new drive shafts (SKF manufacture), the gaiters lasted less than 5 years before splitting. Similarly, the boot at the bottom of the steering column - 7 years, the rubber suspension bands in the seats - 7 years. Don't even ask about the gear lever grommets or the gaiter. Even the pedal rubbers perished after about 10,000km.
What's going on ?
BobH (France)
March 17th, 2017, 2:03 pm
Post Re: Rubber gaiters
I read somewhere that they save money by using less actual rubber in the mix. I can't remember what they supposedly put in instead.
You're not wrong, I do a lot of stuff on Mercedes, and MB rubber parts are really expensive. Or you can buy the super cheap aftermarket. Guess which one will last 20 or 30 years as opposed to maybe as little as 6 months!
Such a shame, as all the work that goes into changing some of these parts is wasted and then needs doing again. And some of them fail catastrophically, even writing off the car in one case I know of.
The market seems to have been flooded with extremely bad quality parts.
March 17th, 2017, 8:07 pm
also the type of rubber should be right for the job it has to do. If you just take the wrong type it might desintegrate sooner...i had a new engine vent rubber that just lasted 3 months...
But i also had parts that were used 50 years and still ok..
March 18th, 2017, 10:36 pm
So what can we do, It would seem un-reasonable to expect the supplier to replace these components, but is it unreasonable? The parts have not given an expected life and are "Unfit for purpose"
Next time you buy "rubber parts" Note the date, keep the receipt, then bitch about it if it fails in an unreasonable time. (whatever you are using these rubber parts for !!)
BobH
March 19th, 2017, 10:13 pm
There are also neoprene gaiters:
Touareg Trail 2007/2009
www.2cvtransahara.nl
March 21st, 2017, 10:14 am
Who sells the neoprene gaiters and do they do all the other ones - like demister vent, gear-lever and handbrake ones. I notice that 2CVclub have changed the design of the floor/steering column gaiter to include a nylon bush for the column to rotate in.
BobH
March 22nd, 2017, 4:48 pm
https://www.burton2cvparts.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=Gaiter
March 22nd, 2017, 7:17 pm
http://www.ecas2cvparts.co.uk/advanced_ ... er&x=0&y=0
March 22nd, 2017, 8:36 pm
The original steering column gaiter has a nylon ring in too.
March 27th, 2017, 8:25 am
There has been a nylon ring in the column gaiter since at least 1967.
BobH
March 28th, 2017, 8:27 am
