View unanswered posts | View active topics It is currently April 29th, 2026, 2:51 am
 Citroen Olcit 11RL
Post Citroen Olcit 11RL
A tech question :)
I came across a Citroen Oltic 11rl
1129 ccm flat 4 engine
Is the bell housing of the gearbox good to go on a 1.3 GS gearbox for fitting in a 2CV or Dyane ?
I now its possible with a Visa 652
February 7th, 2017, 10:32 pm
Post Re: Citroen Olcit 11RL
No. The 1100 ccm is a completely different design.
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
February 7th, 2017, 11:20 pm
You have the gearbox?
if not you need a Citroen GS, GSA gearbox.
You can fit a 602 or 652 engine to a GS gearbox with an LNA bell housing.
February 8th, 2017, 11:09 am
i'm thinking of bying the hole car,so thats why i was intrested in the gearbox combination :)
February 9th, 2017, 12:31 am
my goal is to fit a GS engine in a 2CV so thats way i was asking about this combination with the Olcit :)
February 9th, 2017, 12:36 am
Please put some photos about gearbox. I think the Olcit has same engine-gearbox -layout what G-series has, but never seen any of them. If I recall correct, the Olcit has vented brake disc, if I'm wrong please correct...
February 9th, 2017, 11:08 am
From my Archive....
GS 5 Speed box
Tie Rods been modified.
Ami Super style of drive shaft, better to use 2CV shafts with adaptors.
Drive shafts with large forward angle due to length of gearbox.
GS 4 Speed box.
Rear Cover modified and revised mounting at the top
February 9th, 2017, 2:16 pm
Those drive shaft angles do not look good!!!
February 9th, 2017, 2:37 pm
Yes it has onboard disk brakes, not sure 4 or 5 gears
Still thinking of buying the car
February 11th, 2017, 10:02 am
A pembleton with a big block motoguzzi engine has the shafts at that angle however when you are on full lock the 2cv joint at the wheel is at an incredible angle but it works :D
Loving your ingenuity though
I've some 5speed boxes and probably a short bell housing or two but I'm in Devon in the UK
February 11th, 2017, 10:19 am
