Page 1 of 1
[ 3 posts ] |
CAMSHAFT IGNITION PINS PROBLEM
kitwhite
Joined: June 28th, 2009, 4:24 pm Posts: 97 Location: WEST SUSSEX
One of the pins on the end of the camshaft that holds the springs that control the Advance and Retard of the Points Cam is loose any ideas?
| November 5th, 2016, 4:46 pm |
 Re: CAMSHAFT IGNITION PINS PROBLEM
Kit, as posted elsewhere, I've managed to repair these with a dot of weld at either side of the pin. Just make sure that the pin is sitting square to its backplate before pulling the trigger...
| November 5th, 2016, 7:33 pm |
Taskos
Joined: February 22nd, 2012, 10:34 am Posts: 424 Location: Greece
| November 5th, 2016, 8:48 pm |
Page 1 of 1
[ 3 posts ] |
Users browsing this forum: No registered users and 229 guests |
