View unanswered posts | View active topics It is currently June 19th, 2026, 6:56 am
Reply to topic  [ 1 post ]
 Master cylinder replacement on D6
Post Master cylinder replacement on D6
So all appeared to be going quite smoothly with a master cylinder replacement on the '68 Dyane until starting to put it back together and the actuating rod seems too long. (So probably not so smooth then!) It doesn't go as deep into the new master cylinder as it does in the old one. I don't think that the adjustment nut will take up the slack (and I couldn't shift it easily either) All of the other connections appear correct. I was reluctant to start getting the saw out so thought I'd try asking for advice... Many thanks for your suggestions.
Image201610_MasterCylinderChange by ipacey, on Flickr
October 8th, 2016, 8:31 pm
Users browsing this forum: No registered users and 207 guests
