Reply to topic  [ 4 posts ]
 Rear brake adjuster
Post Rear brake adjuster
Hi All
I had a fair amount of travel on the brake pedal, so though I would adjust the rear brakes.
Near side appears to have adjusted up, but the off side adjuster nuts are just going round and round. What have I sheared. Minimum budget I'm sorry to say. I working in the road and cant really have the car out of commission for to long.
Do the cams part from the bolt, or can the shoes be so worn that the cam loses contact with it?
Advice appreciated.
Roger V
August 9th, 2016, 2:03 pm
Post Re: Rear brake adjuster
Daras Rich sells replacement brake adjusters.
He has a web site. retrospecparts.com I think.
John Jordan
August 14th, 2016, 6:51 pm
You can put a spot of welding on cams in the inside of the brakes. If they are not to used.
August 15th, 2016, 5:35 pm
Thanks AZL57
That is a thought. :)
Roger V
August 15th, 2016, 7:09 pm
