View unanswered posts | View active topics It is currently June 19th, 2026, 9:57 am
Reply to topic  [ 3 posts ]
 Oil change problem?
Post Oil change problem?
Hi all.
I am after some reassurance.
Today I changed the oil/filter on my 1986 2cv.
The filter took some effort, with a strap, but finally spun off. I then noticed that the threaded tube onto which the filter spins was protruding 2-3cm further out than it should and was in the process of unwinding away from the crankcase.
I wound the tube back into the housing until it was tight.
Filled with new oil I started the engine and the oil light went out as it should.
Now, because I don't know what's inside the casing behind this tube, I'm hoping that this occurrence will not have caused anything untoward.
Thanks for your thoughts.
August 9th, 2016, 1:55 pm
Post Re: Oil change problem?
Its just a threaded tube.
Screw it back in again it will be ok.
August 13th, 2016, 9:11 pm
Thanks for that: my nightmares are now abated!
August 14th, 2016, 3:12 pm
Users browsing this forum: No registered users and 215 guests
