Reply to topic  [ 7 posts ]
 Cylinder head erosion
Post Cylinder head erosion
Greetings
Took the heads off one of my Visa engines- this is the 'good' engine.
Once I had cleared off the black crap, I found it had lots of pits by the exhaust valve seat and on the edge of the combustion chamber- just starting to eat into the flat bit where the barrel sits.
The exhaust valve seat is pitted too.
Piccy:
Is the head scrap or still useable?
June 21st, 2016, 12:44 am
Post Re: Cylinder head erosion
I have a pair on an engine I used before if you need - also rebuilt cam by Kent cams etc etc
June 21st, 2016, 9:08 pm
Is that caused by pinking?
July 8th, 2016, 10:30 pm
certainly looks like there was some. Its always at the edge opposite the sparkplug where the hump of the piston is closest to the head
July 9th, 2016, 9:38 pm
That would have taken some doing on a Visa 652, considering that the ignition timing was set by Citroen.
Mind you, many years back I heard about some characters who locked in the extra 10* vacuum advance, reckoning that made the engine more 'lively', just as long as you ignored the resultant pinking, of course.
Now I think about it, they were based somewhere in the north-east... :roll:
July 9th, 2016, 10:57 pm
I've got to look at all options- any chance of some pics of the heads you have got?
July 12th, 2016, 9:04 pm
Heads are fine - with studs, valves and no erosion
July 13th, 2016, 9:24 am
