Reply to topic  [ 8 posts ]
 Brake fluid issue
Post Brake fluid issue
Hi everyone
Bedouin has been stood for 2 years. Recently put my foot on the brake pedal and it went to the floor. Bought a new master cylinder (Delphi LM23519) and was dismayed when removing reservoir as both clear and green fluid came out. :o
Car is 2cv based and registered in 1978.
It has front disk brakes.
What options do I have?
April 22nd, 2016, 3:53 pm
Post Re: Brake fluid issue
Are you suggesting that you found DOT fluid in your reservoir ?
I've Been Wrong Before.
April 23rd, 2016, 4:43 pm
If it has discs it must be LHM normally.
April 23rd, 2016, 6:29 pm
Roger,
unfortunately, DOT3/4 brake fluid sinks below LHM, so will have contaminated any components in an LHM-based braking system which it has contacted.
If you're (relatively) lucky, it may only be the master cylinder which has been affected.
If any of the brakes have been bled, the calipers and/or rear wheel cylinders may need replacement seals.
ImageBrake fluid? by slcchassis, on Flickr
April 24th, 2016, 1:27 am
You forgot the slice of lemon and the straw Ken.......
April 24th, 2016, 10:49 pm
Lol and a little umberrella.
Thank you all for your help guys.
Any tips on getting the pin out of the master cylinder?
April 24th, 2016, 11:45 pm
ok .... forget the old master cylinder ...
Im returning the incorrect MC ....
I've ordered the correct MC for LHM
just calipers and wheel cylinders to worry about now ..... and possible the pipes in between.
See you in a field somewhere.
You will have to be quick though, as I will be the one coming in the entrance, screaming as I cross the field and making a new exit in the hedge because my brakes have failed.
I can be revived with cider.
April 25th, 2016, 6:57 pm
Ha :) Cider works for me too :)
April 25th, 2016, 8:03 pm
