Reply to topic  [ 4 posts ]
 Cooling
Post Cooling
Will it have any harmful effect if you build blow cooling jacket on a modern 602 on to have an output like an old M4. ie no hot boxes on the exhaust.
Image 2cv special 0,6Tii
viewtopic.php?f=5&t=1610
January 1st, 2016, 8:40 pm
Online
Post Re: Cooling
My 2 Deg C.
If the air-flow is not as restricted the Engine will run cooler.
January 2nd, 2016, 1:43 pm
Post Re: Cooling
subarupete wrote:
My 2 Deg C.
I agree.. In my imaginition it helps alot if You open the triangle shaped pieces at the rear....
January 2nd, 2016, 2:49 pm
Post Re: Cooling
they are open.
Plan to build them is. I have not space to heat the boxes on the exhaust due turbo. and I want to make a heating system.
January 2nd, 2016, 6:30 pm
