Dodgy Charging
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=5747
Page 1 of 1
Author:  adam_d [ December 19th, 2015, 6:48 pm ]
Post subject:  Dodgy Charging
I've noticed a bit of flickering and dimming when I've had the lights on recently, so had the multimeter out today to have a quick check what's going on.
Car off: 12.4v after standing, so battery seems fine.
Idling/revving with nothing on: 14.4/14.5v
Lights on at idle: 13.2/13.3v
Lights on revving: seems to top out around 14.9/15v, no signs of battery boiling currently.
I'm going to check out the connections to the regulator tomorrow but haven't got a spare to try out, is it also worth checking the alternator brushes are alright?
Thanks.
Author:  Taskos [ December 19th, 2015, 8:53 pm ]
Post subject:  Re: Dodgy Charging
Most probably the ( French) connections , bullets or switched.
Author:  adam_d [ December 20th, 2015, 5:05 pm ]
Been out and checked the light connections today, as you predicted pretty ropey. The switch looks OK.
I've cleaned them up best I can which has helped a little bit and reduced some of the flickering, but while I'm on, has anyone got a diagram/instructions for converting them to relays? It's something I've had in the back of my mind for a while which I know should be fairly easy, but just want to make sure I get it right.
Author:  AZL57 [ December 20th, 2015, 9:37 pm ]
clean your connections mass cable to the gearbox and also the connexion between the altenator and the manifold.
Author:  Taskos [ December 21st, 2015, 7:25 pm ]
Elementary...
Author:  adam_d [ December 21st, 2015, 8:42 pm ]
Spot on, thanks.
Author:  ayjay [ February 9th, 2016, 2:47 am ]
take the lighting switch apart and polish the brass drum inside it corrodes and causes resistance make sure the dim/dip system has been disabled-u can tell if the switch is the prob as it gets hot after a time with the lights on
if it needs cleaning
