Reply to topic  [ 6 posts ]
 MCC Wiring Loom
Post MCC Wiring Loom
Hi,
On one of our cars the wireloom caught fire last year.. Since we didn't need the car urgently I put a new MCC (Club Cassis) wiring loom in the car.
All works, except the voltage regulator and wiper motor.
On the normal loom these have connectors that only fit one way, on this loom we each connection has sepeprate connectors and cant figure out which is which..
Anyone here has any experience with this loom?
November 30th, 2015, 9:22 am
Post Re: MCC Wiring Loom
No experience with this particular loom, but it should be easy enough to find out with the help of a multi-meter and a wire diagram.
November 30th, 2015, 10:17 am
Got the wiper motor sorted with a MCC data sheet..
Voltage regulator still open..
November 30th, 2015, 10:50 am
Ah well, just did a good peek at the files I received and the voltage regulator is mentioned as well..
Might be able to get te car working today...
Is has to be, since the other 2cv had to be layed up for the next three months...
November 30th, 2015, 5:20 pm
It all seems to work now..
Wiper motor not as usual, since it starts running when car is put on contact.. 12V then goes directly to the motor. This is with the swicth disconnected.
Now temporarily sorted by putting a switch in that wire, so the wipers stop at any given point...
December 1st, 2015, 9:58 am
switch that wire with the one that gets power through the actual wiper switch, and everything should be working as intended.
December 1st, 2015, 11:31 am
