Reply to topic  [ 3 posts ]
 Gearbox\clutch fork type
Post Gearbox\clutch fork type
Think the clutch fork has cracked and bent ,either that or the clutch pressure plate fingers have bent
Won't know for sure until after the engine drip covers are off and its jacked up
The clutch biting point dropped in the space of 1 day and again after unadjusted the lock nuts on the cable
I had a quick look online,the car is a 76 Ami 8 ,is the clutch fork the same as a later 2cv one does anyone know?
Thanks
Matt
October 28th, 2015, 10:00 pm
Post Re: Gearbox\clutch fork type
Not pulled the cable thru the bulkhead?
Mike
October 29th, 2015, 2:23 am
All the same from 1970 onwards.
http://www.ecas2cvparts.co.uk/clutch-op ... -p-84.html
Might be worth checking that the 4 nuts securing the engine and gearbox are present and are tight; it's not unknown for the lower ones to work loose, which would have an effect on things...
October 29th, 2015, 2:34 am
