View unanswered posts | View active topics It is currently June 19th, 2026, 11:25 am
Reply to topic  [ 8 posts ]
 Engine identification
Post Engine identification
Can someone tell me what this engine is and what carb is required for a conventional clutch please.
A60 / 635 Sn 0901006847
BobH
April 3rd, 2015, 11:44 am
Post Re: Engine identification
If it is an M28 engine, could I fit an exhaust/inlet manifold from my old AK2 engine with the PCIS 34 carb. The Output HP seems to be the same for an AK2 with PCIS 34 and the AM2A with the 26 x 35 CSIC carb ?
April 3rd, 2015, 11:58 am
1981, late model M28/1 engine ( 8.5:1 CR), twin choke 26/35 CSIC carburettor (without throttle closing dashpot)?
Edit. A single choke manifold setup will fit, but best to slacken the cylinder head stud nuts to allow things to line up correctly.
BobH
April 3rd, 2015, 12:05 pm
Thanks Ken - heads have been taken off, so no problem with alignment there.
BobH
April 3rd, 2015, 5:43 pm
Is the direction of the throttle operation the same on the two carbs?
April 5th, 2015, 1:29 am
I can't say as I only have the 34 pics. Where the throttle lever pivot is above the butterfly, and opens butterfly when pushed forward. (Anti clockwise when viewed from LHS) But then, this is for a LHdrive car - Can't comment on RHD.
April 5th, 2015, 7:58 am
That's fine if it's going in a car with a rod (not cable) operated throttle.
April 6th, 2015, 12:56 am
I screwed an other home made lever pointing down to the original lever of my 34 pics, so it can be cable operated now.
April 12th, 2015, 11:45 pm
Users browsing this forum: No registered users and 233 guests
