12 or 18 HP
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=5594
Page 1 of 1
Author:  H Clew [ March 22nd, 2015, 5:32 pm ]
Post subject:  12 or 18 HP
I'm working on my spare engine. I'm pretty sure it's the correct one for the car.
By bore and stroke, it's a 425.
What is the defining difference between the 12 and 18 HP engines? I have the 4 stud heads, but the Solex 28 carb is a small throat, about 17 mm at the narrowest.
David
Author:  AZL57 [ March 22nd, 2015, 6:35 pm ]
Post subject:  Re: 12 or 18 HP
12 HP has 3 stud heads. Solex must be correct the 12 HP has a solex 26.
Author:  H Clew [ March 22nd, 2015, 8:07 pm ]
Thank You
That's what I thought about the heads, but I don't know enough to say with certainty.
David
Author:  ken [ March 22nd, 2015, 9:16 pm ]
Further to AZL's post, venturi on a Solex 28 as fitted to 12HP (A53 engine) was 22mm, a Solex 32 on an 18HP (A79/0 engine) would have been 28mm.
The engines also have different compression ratios, which Citroen usually marked on the piston crowns, 7.5:1 for the earlier engine & 7.75 for the later.
