Reply to topic  [ 4 posts ]
 Solex type 28 Carb linkage
Post Solex type 28 Carb linkage
On this small carb, at the starting mechanism, there are two levers on the same shaft. One operated by cable, the other spring loaded.
http://s1305.photobucket.com/user/HClew/library/425
How tight/loose is the spring operated lever supposed to be?
In the picture above, the spring doesn't return it all the way. Is the spring too long? Is the picture showing the proper "at rest" position?
David
March 20th, 2015, 4:29 pm
Post Re: Solex type 28 Carb linkage
Spring seems ok it should return the choke to half way position. You pull it to start the car leave it in half position running the car for a while to warm up and than push the choke button all the way back .
March 20th, 2015, 6:54 pm
Yup mine does that - the last 1/8th inch of movement is only achievable by finger on the lever on the carb, cant get the cable to close it all the way.
Mike
March 21st, 2015, 1:05 am
That makes sense.
On mine, the dimple on the longer lever was on the wrong side, and the shorter lever was bent out of the way.
Works better the right way.
http://s1305.photobucket.com/user/HClew ... f.jpg.html
March 21st, 2015, 2:43 am
