rear drums.
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=5592
Page 1 of 2
Author:  poprodder [ March 19th, 2015, 12:47 am ]
Post subject:  rear drums.
hi,
is it easy to remove rear drums?
reading in haynes book of lies looks complete nightmare!!!!
cheers chris.
Author:  Russell [ March 19th, 2015, 12:51 am ]
Post subject:  Re: rear drums.
Really easy. Knock staking out of hub nut, undo hubnut, remove drum. That's it.
Author:  poprodder [ March 19th, 2015, 1:00 am ]
cheers russ,
Author:  Russell [ March 19th, 2015, 1:26 am ]
Front drums are a cock, mind you.
Author:  smyth602 [ March 19th, 2015, 1:56 am ]
You might need to back off the shoe adjusters if the drum has developed a wear lip - the bottom ones are likely siezed and will need a hefty dose of WD-40 or equivalent.
Author:  poprodder [ March 19th, 2015, 10:12 am ]
cheers
Author:  ChrisW [ March 19th, 2015, 3:21 pm ]
If your unlucky you may need a simple puller - available in ECAS etc
http://www.ecas2cvparts.co.uk/brake-dru ... -1616.html
Author:  poprodder [ March 19th, 2015, 4:15 pm ]
been looing at them, seems easy enough to make.
cheers chris.
Author:  smyth602 [ March 19th, 2015, 5:04 pm ]
I'm sure a puller is the ideal choice, but i always manage with two beefy screwdrivers...
Author:  AZL57 [ March 19th, 2015, 6:18 pm ]
and old wheel will make a great puller.
