 rear drums.
Post rear drums.
hi,
is it easy to remove rear drums?
reading in haynes book of lies looks complete nightmare!!!!
cheers chris.
live life to the full, it can end so suddenly.
March 19th, 2015, 12:47 am
Post Re: rear drums.
Really easy. Knock staking out of hub nut, undo hubnut, remove drum. That's it.
March 19th, 2015, 12:51 am
cheers russ,
March 19th, 2015, 1:00 am
Front drums are a cock, mind you.
March 19th, 2015, 1:26 am
Haggis Muncher
You might need to back off the shoe adjusters if the drum has developed a wear lip - the bottom ones are likely siezed and will need a hefty dose of WD-40 or equivalent.
March 19th, 2015, 1:56 am
cheers
March 19th, 2015, 10:12 am
If your unlucky you may need a simple puller - available in ECAS etc
http://www.ecas2cvparts.co.uk/brake-dru ... -1616.html
March 19th, 2015, 3:21 pm
been looing at them, seems easy enough to make.
cheers chris.
March 19th, 2015, 4:15 pm
Haggis Muncher
I'm sure a puller is the ideal choice, but i always manage with two beefy screwdrivers...
March 19th, 2015, 5:04 pm
and old wheel will make a great puller.
March 19th, 2015, 6:18 pm
