View unanswered posts | View active topics It is currently June 19th, 2026, 11:27 am
 Economy Temp Guage
Online
Post Economy Temp Guage
Pictures of Parts to make either Oil Temp or CHT gauge.
Total Cost about £20.00 (TC 12.00 + Battery £4.00 + Display £3.00 + Plug £2.00)
I used an RS TC I had in the junk box as it has a washer which allows it to be bolted down.
The TC supplied with the display is OK but needs to be attached in a reliable way
For CHT use probe
http://www.ebay.co.uk/itm/Thermocouple- ... 3a70c319c4
The display unit is powered by a 9 volt battery, so you have to remember to turn it off.
It CANNOT be supplied from the car 12 volts due to "earth loops".
One side of the TC is connected to ground, such that the TC and display are isolated from the vehicle earth.
Need to rig a up a relay to switch the 9v battery on/off with the ignition.
Clamp
Thermocouple
RS Stock No.621-2271 £14.08
Clamp with Thermocouple
Cable Tied on to output pipe of the oil cooler
LCD Display
Ebay £2.99 delivered !!
http://www.ebay.co.uk/itm/Digital-LCD-D ... 27edc921b9
January 21st, 2015, 4:37 pm
Post Re: Economy Temp Guage
that is brilliant, i like cheap :D
cheers chris.
live life to the full, it can end so suddenly.
January 22nd, 2015, 9:40 pm
:o High Tech Gauge :o
It's always better if you can avoid the drilling! ;)
I will try it in my own temp sender, temporary living inside the head cowling.
Have you checked the optimum oil temperature ?
I've Been Wrong Before.
January 23rd, 2015, 9:02 pm
If you like cheap, you must like this:
http://www.lightinthebox.com/nl/water-t ... 53768.html
Hope the link works in other countries as well!
Greetzzzzzz, Rusty
bitten by the Citobug...
January 23rd, 2015, 11:45 pm
That's for water temperature. :|
January 24th, 2015, 12:20 am
So, whats the diffrence...... I wouldn't go much over 120 degrees for oil...
Rusty I think with some fiddeling you can even use it for Lambda controller....
I like it.... cheap cheap cheap...
January 24th, 2015, 12:43 am
Here you go....
http://www.lightinthebox.com/nl/auto-motor-universele-smoke-lens-2-52mm-40-150-c-indicator-olie-temp-gauge-witte-led-tempreture-meter_p2656118.html
January 24th, 2015, 1:15 am
Exactly what geo says, temperature is temperature,
if you want to have it a bit more fancy looking, take it apart, redo the interior change it into oil temperature, and put it back together.
I ve seen people putting the sensor in the valve covers, or in the center of the oil sump drainplug. I vaguely remember on (visa) engines there is a flat spot somewhere on the sump where you could drill and tap thread and put the sensor in (take the engine apart for that ;) )
Greetzzzz Rusty
January 24th, 2015, 8:03 am
Online
Economy...money/time/simple...
I can do air,water,oil and Exaust!
January 24th, 2015, 10:17 am
Online
Also Exhaust......
January 24th, 2015, 10:22 am
Users browsing this forum: No registered users and 231 guests
