subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2258 Location: Near Monmouth
 Economy Temp Guage
Pictures of Parts to make either Oil Temp or CHT gauge. Total Cost about £20.00 (TC 12.00 + Battery £4.00 + Display £3.00 + Plug £2.00) I used an RS TC I had in the junk box as it has a washer which allows it to be bolted down. The TC supplied with the display is OK but needs to be attached in a reliable way For CHT use probe http://www.ebay.co.uk/itm/Thermocouple- ... 3a70c319c4The display unit is powered by a 9 volt battery, so you have to remember to turn it off. It CANNOT be supplied from the car 12 volts due to "earth loops". One side of the TC is connected to ground, such that the TC and display are isolated from the vehicle earth. Need to rig a up a relay to switch the 9v battery on/off with the ignition. Clamp Thermocouple RS Stock No.621-2271 £14.08 Clamp with Thermocouple Cable Tied on to output pipe of the oil cooler LCD Display Ebay £2.99 delivered !! http://www.ebay.co.uk/itm/Digital-LCD-D ... 27edc921b9
| January 21st, 2015, 4:37 pm |
poprodder
Joined: January 25th, 2014, 11:23 pm Posts: 134 Location: norfolk
 Re: Economy Temp Guage
that is brilliant, i like cheap cheers chris.
_________________ live life to the full, it can end so suddenly.
| January 22nd, 2015, 9:40 pm |
Taskos
Joined: February 22nd, 2012, 10:34 am Posts: 424 Location: Greece
 High Tech Gauge It's always better if you can avoid the drilling! I will try it in my own temp sender, temporary living inside the head cowling. Have you checked the optimum oil temperature ?
| January 23rd, 2015, 9:02 pm |
Rusty
Joined: January 12th, 2010, 10:33 am Posts: 193 Location: Koudekerk ad Rijn, Netherlands
If you like cheap, you must like this: http://www.lightinthebox.com/nl/water-t ... 53768.htmlHope the link works in other countries as well! Greetzzzzzz, Rusty
_________________ bitten by the Citobug...
| January 23rd, 2015, 11:45 pm |
Taskos
That's for water temperature.
| January 24th, 2015, 12:20 am |
lpgo
Taskos wrote: That's for water temperature.  So, whats the diffrence...... I wouldn't go much over 120 degrees for oil... Rusty I think with some fiddeling you can even use it for Lambda controller.... I like it.... cheap cheap cheap...
| January 24th, 2015, 12:43 am |
lpgo
| January 24th, 2015, 1:15 am |
Rusty
Taskos wrote: That's for water temperature.  Exactly what geo says, temperature is temperature, if you want to have it a bit more fancy looking, take it apart, redo the interior change it into oil temperature, and put it back together. I ve seen people putting the sensor in the valve covers, or in the center of the oil sump drainplug. I vaguely remember on (visa) engines there is a flat spot somewhere on the sump where you could drill and tap thread and put the sensor in (take the engine apart for that  ) Greetzzzz Rusty
| January 24th, 2015, 8:03 am |
subarupete
Economy...money/time/simple... I can do air,water,oil and Exaust!
| January 24th, 2015, 10:17 am |
subarupete
Also Exhaust......
| January 24th, 2015, 10:22 am |
