Rear Brake Pipe
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=5450
Page 1 of 2
Author:  Simon Crook [ November 10th, 2014, 10:52 pm ]
Post subject:  Rear Brake Pipe
Anyone got a good picture of the route a rear brake pipe takes from the fluid reservoir down to the chassis!
thanks
Simon
Author:  samfieldhouse [ November 11th, 2014, 12:00 am ]
Post subject:  Re: Rear Brake Pipe
Can take a pic in the morning but it looks a bit like:
Author:  Simon Crook [ November 11th, 2014, 12:04 am ]
Thanks Sam for your input thus far! if you could take a piccie that would be of great help thank you
Author:  banjo [ November 11th, 2014, 12:18 am ]
http://www.franzose.de/en/Citroen-2CV/A ... /ANR13039/
The link above shows a good diagram of the brake pipe you as about, although not how it lies along the chassistant :-):-)
Author:  citroenboat [ November 11th, 2014, 2:01 am ]
Left or Right hand drive, old drum, drum or disc?
mike
Author:  ayjay [ November 11th, 2014, 2:09 am ]
Author:  Simon Crook [ November 11th, 2014, 9:37 am ]
Right hand drive, discs - on the race car I've fitted the pipe its just does not look right to me!
Author:  samfieldhouse [ November 11th, 2014, 1:47 pm ]
Author:  Simon Crook [ November 11th, 2014, 2:32 pm ]
thanks Sam its sort of helped
Author:  Norman [ November 11th, 2014, 8:14 pm ]
Simon
The rear brake pipe should come down onto the top surface of the chassis and be secured. ( there should be a hole to take a pipe clip). If its SLC its a tapped hole.
It is then curved over the chassis outer edge (quite a sharp u bend) where it then runs along the chassis inside face and behind the suspension tubes etc.
Picture attached is looking down from above between exhaust pipes on a left hand drive. Right hand drive car is just a reverse. You can see the pipe clip holding the brake pipe flat to the chassis top (chassis is blue in picture)
The brake pipe should have the protective cover (blue in Sams pictures) to protectthe pipe where it bends around this area.
