 Compression - I've had better days
Post Compression - I've had better days
Just finished futzing with the AK after a couple of days holidaying in the Malvern hills.
The motor just doesn't perform as well as the old Acad.
Checked the timing, spot on.
Check the valve clearances - spot on.
Check the compression... oops, one side 150psi and the other is down to 100, and these are supposed to be 9:1 pistons.
I've re-torqued the head down and now it's up to 125psi
I feeler a tear down is in order, or might just swap to the spare motor.
What would you do - strip the current engine in situ, or swap the motor?
October 25th, 2014, 4:06 pm
Online
Post Re: Compression - I've had better days
My 2psi
Take the head off the low side and clean up the seating of the barrel at both ends.
October 25th, 2014, 4:51 pm
The thing is, they're both low for 9.0:1 pistons, which should read more like 175 psi.
Engine hot and throttle wide open, of course... ;)
Bottom of the barrel? That sounds a rather novel idea.
subarupete wrote:
My 2psi
October 25th, 2014, 7:46 pm
tappets can have quite a marked effect so make sure they are OK especially if the head studs have been re done. after that its usually scuffed bores
October 25th, 2014, 10:49 pm
might be a 2 stroke :)
October 26th, 2014, 3:26 am
Just taken off the 2nd cylinder head from the spare motor in preparation.....
When you find the stud is glued in with firegum...
I've had better days... :lol:
November 7th, 2014, 7:19 pm
Online
That's repairable, get it plug welded (alu). Drill and tap.
November 7th, 2014, 7:30 pm
bolt and washer for the cheap bodge
November 10th, 2014, 9:57 am
Sean I'm shocked; that level of bodgery shows a lifetime of practice. :lol:
It's all welded up and all the M7 threads have been helicoiled for a bit of futreproofing.
I'll post a piccie when I pick them up on Sat.
November 10th, 2014, 11:39 am
All repaired
Now what's the weather forecast this weekend?
November 14th, 2014, 11:32 pm
