Substitute for paper gaskets?
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=5429
Page 1 of 1
Author:  Dennis [ October 22nd, 2014, 8:27 am ]
Post subject:  Substitute for paper gaskets?
Apologies for coming back to my H-van, again, but ....
I'm just about to drop the sump to clean out the years of accumulated muck inside - my 1964 HY-72 is the old type that does not have an external oil filter. The sump should have two cork semi-circular gaskets at each end (and I have new ones) and - I think! - a paper gasket for the much larger square surfaces that at present squirt oil all over the place.
Is there a jointing paste/liquid etc that will do the job better than another very thin but original paper gasket? I can't help but think there is something better than the Red Hermetite that I just smear all over the engines of the old BL cars I was "servicing" in the 1960s.
Suggestions definitely welcome.
Author:  subarupete [ October 22nd, 2014, 9:07 am ]
Post subject:  Re: Substitute for paper gaskets?
Maybe this
Hylomar Blue None Setting Gasket & Setting Compound 100g
Used aluminuim to aluminuim 2cv gearbox etc
Author:  Rhythm Thief [ October 22nd, 2014, 9:41 am ]
Or get hold of some gasket paper and cut your own. The slightly thicker stuff works well.
Author:  Dennis [ October 22nd, 2014, 10:11 am ]
Thanks - I had considered making my own - it can't be that difficult, can it? However I don't know how thick the original paper was and the special gasket papers seem to come in quite a lot of thicknesses.
And it goes without saying that after posting the original question I found that a made-to-measure gasket - which looks about right - was available at not too steep a price.
Perhaps I'll try belt and braces - paper and the Hylomar Blue. It can't give a worse result than what I have at present.
Author:  Geert [ October 22nd, 2014, 10:51 am ]
Products of that supplier are good !
So no worries about quality there !
Author:  Dennis [ October 22nd, 2014, 12:01 pm ]
Thanks Geert - I've now ordered Der Franzose's paper gasket, and a tube of the Hylomar Blue too. Funnily enough, they don't seem to have it in the Aurillac branch of Feu Vert.
Author:  Joolz [ October 22nd, 2014, 6:03 pm ]
RTV silicon seems to be about the best 'gasket in a tube', imho.
Not really a fan of blue hylomar, it skins over really quickly making it hard to get an even smear, though it does usually seal fine, particularly between castings.
Author:  ken [ October 22nd, 2014, 11:55 pm ]
I'd used Red Hermetite for more years than I care to remember, but now that it's no longer available, wish I'd switched to Wellseal sooner... :lol:
It's perfect for sealing the joints between crankcase halves, also gearbox main casing to bell housing and rear cover joints.
http://www.ebay.co.uk/itm/Wellseal-Gask ... 1425205711
